Airbag Fault after running Vag-Com
Old May 13, 2008 | 09:26 PM
Dallas09's Avatar
Default RE: Airbag Fault after running Vag-Com
does the light self test when you turn the car on?
Old May 13, 2008 | 09:52 PM
djlouieboom's Avatar
yes the light self test's and goes out and stays out.
Old May 14, 2008 | 09:25 PM
Dallas09's Avatar
Well its gotta be the module then if its not clearing, you could risk it and just keep driving with it who knows what itll do or not do... Kinda scary that it can be screwed up and not even turn on the light they could probably get sued for that too. You could check the measuring blocks and see if they look normal, not that itll tell you much about a failed module though. To answer your question about fixing it through VAG, you can recode the module to specify how many airbags it has and what not but not reflash it or anything that would fix it. I guess the last thing id do before replacing it is disconnecting the battery over night and then checking the codes and clearing it one more time otherwise theres probably not much more to do. (Sorry i didnt see that you had mensioned the light self tests in your first post i shoulda looked)
Old May 15, 2008 | 09:07 AM
Well i disconnected the battery overnight, and the code still wont clear, and yes the airbag light still self test's and goes out, maybe sooner or later ill buy a module ,.... maybe.
Old May 15, 2008 | 06:35 PM
Dallas09's Avatar
Sorry to hear that. Yeah you could leave it, i guess if it were me and i was gonna leave it for a while id pull the fuse or something id be kinda afraid it would randomly go off since the computer in there is screwed up but theres still a chance it might work ok to so idk i doubht that would happen anyway.
tenstringer009
Jan 1, 2014 11:03 PM
johnmorgan1948
May 23, 2013 03:07 PM
vserghi
Jun 22, 2009 07:33 AM
jluckuck
May 17, 2008 04:04 PM
gwaxman
Feb 12, 2006 12:41 PM
