Did you install it on per APR's install instructions. When I installed mine I had no vibration issues. You might need to adjust your snub mount to get rid of your vibration issues.
It's fairly normal since the urethane is so much stiffer than stock. It'll vibrate even more if you have an automatic since with a manual you can decouple the engine from the transmission.
