Audi error codes a3 2004 tdi?
Old Aug 26, 2015 | 01:52 AM
jackson-shawn's Avatar
Default Audi error codes a3 2004 tdi?
have 4 codes come up on adi could someone tell me what i would need to do to fix?
1.cylinder 4 glow plug circuit (electical fault0674
2.cylinder 3 glow plug circuit (electical fault0673
3.egr system:insufficent flow0401
4.boost pressure regulation :limit exceeded (overboost)p0234
Launch CRP129 won the prestigious Motor Top 20 Tools Award.The CReader Pro 129 was recognized by Motor Magazine’s editorial staff for its overall uniqueness and “Wow” factor, along with the innovation and effectiveness it brings to today’s technician.
Old Aug 26, 2015 | 08:23 AM
dave944's Avatar
On the Glow Plug issues, I'd check the wiring connections (put some di-electric grease in the connectors to keep water and such out) especially the wiring harness ground connections to the block or body. Loosen them up and retighten to be sure they're making good contact.
The EGR and Turbo issue could be a vacuum supply issue if they get their vacuum from the same line. Check and make sure the vacuum lines that go the actuators are not cracked or leaking. The vacuum source for these may not be manifold vacuum but instead use a vacuum pump. However, I can't say for sure on your car.
autonumenbella
Jul 6, 2015 07:27 AM
Rugby8Matt
Nov 10, 2013 04:13 PM
whann79
Sep 16, 2013 10:14 PM
rbv24
Dec 30, 2011 07:50 PM
gs430
Nov 9, 2005 10:16 AM
