Audi Technical Info Manual
Old Jun 27, 2006 | 08:17 PM
Rickster's Avatar
Default Audi Technical Info Manual
This workshop cd covers all aspects of Audi Repairs (and most other cars) you can check repair times for most parts (you can now check Audi dealerships not telling you wrong hours at inflated prices). This cd will do professional quotes etc and service check lists, tell you where all components are etc and even all fault codes and how to check sensors using ohm meter, £4 interested? £4 free P+P, I promise you wont be disappointed and like I said cd covers most cars so if you sell your Audi cd still useful some of the info covered is listed below
General Information
Climate Control System
Wiring Diagrams
Service Indicator Reset
Braking Systems Including ABS
Air Bags
Component Locations
Timing Belts / Chains
Torque Settings
Fuses And Relay Locations
Diagnostic Trouble Codes
Service Interval Check Sheets
Engine Management / Running Problems Trouble Shooter
And Much More
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE:IT&ih=001
Thanks Rick
Please note this disc is listed as VW Cars But All Audi Range is on same disc just tell me which car and I can double check for you
Old Jun 29, 2006 | 10:17 PM
dankhound's Avatar
Default RE: Audi Technical Info Manual
The problem with those times is that they are made up by people that have never seen an audi let alone worked on an audi. The times it takes to actually perform repairs is almost always greater than the actual time. A great example is the 4 link suspension. Most labor times call for 1.5 hours for upper control arm. Notice not arms, just one. But you should replaced them in pairs. That brings the total time to 3 hours. Most shops however will only charge two hours to replace both. But if the person who determined those times had ever worked on an audi the labor time would be 2 hours for upper control "arms". And if your talking audi warranty times dont even get me started. Those numbers are developed by a computer. Seemingly at random. And thats where the real travesty lies. Technicians have a family to feed to and when audi doesnt pay them squat to fix your car under warranty, they have to make it somewhere, and in the long run the consumer suffers for audi's greed.
liviumarius
Sep 14, 2012 10:41 AM
Miles@TireRack.com
Apr 28, 2011 04:51 PM
Miles@TireRack.com
Apr 15, 2011 12:54 PM
mizzike2555
May 14, 2008 01:43 PM
Rickster
Jun 27, 2006 04:44 AM
