Battery Location
As dan908 said its accessible from the rear passenger area. There are two screws to remove under the front of the rear set cushion.
Question is are you needing to access it to replace the battery or for some other reason?
FYI... If you need to jump the car to start it or something like that, you can access a positive post in the engine compartment. If you have the manual it should describe this. But if you do need actual access to the battery for maintenance or replacement its under the rear seat cushion.
intergalactic
Mar 5, 2012 09:42 AM
RickA6
Apr 11, 2011 11:21 PM
salinas
Dec 11, 2007 08:09 PM
salinas
Dec 2, 2007 05:14 PM
