BRAKE LIGHT FLASHING ON DASHBOARD
Hello -
I just purchased a 04, Audi A6, 3.0, quattro, V6 with about60,000 miles
This morning when I got to work before I turned the car off I noticed my BRAKE light “flashing” constantly on the dashboard. Should I be worried or is this a common problem for Audi’s? I am going to take it to be serviced – But I just wanted to be prepared for a huge out of pocket expense or a major problem. [/b]
Also should I drive the car or have it towed? [/b]
[/b]
THANKS for any insight that you give….
[/b]
[/b]
[/b]
ORIGINAL: UpstateNYA4
You should buy the pads and rotors and install them yourself - you'll save probably more than $300 of that money.
There's always next time!
Hi,
When I try to start the vehicle, the vehicle made some sound and didn't start. and after sometime brake light was flashing. The battery is not down as I was able to open the door using my remote key which otherwise is not possible.
The vehicle was running fine till yesterday night. Mine is 2002 Audi A6.
Can you please help what might be the problem? Thanks in advance for your help.
Thanks,
-Sonali
Thanks,
-Sonali
sometimes a flashing brake light could mean the abs controller is dead as well, most commonly it is related to fluid level. If you do have a condition with low fluid level you should have the brake system inspected. The fluid does not just disappear, there is a leak somewhere. Low pads should flash a symbol like this on the cluster "(O)" on the later model cars.
