breaks? HELP!
Ok, here goes...
So I just bought an A6 2.7biturbo from a guy in Tulsa. He bought a Mercedes and left the Audi alone for like 3 months. When I went to buy it, it had rust on the rotors, no suprise there. Anyway, it now makes this "whomp whomp whomp whomp" sound when you break. Mostly from the front. Gives some feedback through the break pedal, but not any wiggle in the steering pedal. I haven't taken the wheel's off to check it out, but was wondering if I had a pad, caliper or rotor problem there. The diagnostic computer thingy says that everything is ok, but the sound is VERY loud when breaking. Otherwise a great ride. Smooth and handles well in the corners.
OH. By the way, the CD player says CD ERR1 when I put a cd in. Tried to use a cd cleaner but still no luck. Should I take the whole thing apart and clean it? And the CD-Changer only plays out of the right speakers, but the radio uses all the speakers so I'm assuming there's a connection for the left side not installed well. Finally the sunroof **** is wiggly and you have to hold it to the side to make it work. The dealer said that's common and the part is like $100 to fix.
Please let me know soon anyone!
Thanks,
Steve
2001 Audi A6 2.7biturbo
All stock. Why mess with perfection? LOL
Thanks,
Steve
about your brakes - does the noise only occur when your braking? I had a squeal in my brakes at low speeds and braking... my guess is that you have a warped rotor(s)... pads are simple, they either have enough pad or not enough pad..
More Info...
They make a jackhammer sound not a squeal. When breaking from fast to slow. Doesn't really do it at slow speeds in parking lots and stuff. There's a "grey" spot in the front passenger rotor. I'm guessing some kind of leftover from the rust. Anyway, just curious. I don't want to drive all the way into the Audi dealer and have them tell me it's like something simple I could fix myself.
Thanks!
Steve
Thanks!
Steve
ORIGINAL: oklahoma audi
How do you pull out and clean the ABS sensor? Wouldn't it trip the ABS light?
Yup, it can throw a code.
Do you mean it would throw a code by cleaning them or it should be throwing a code now? I don't have any codes now, but I don't want to do something stupid and create more problems for myself. You guys have done this before with no problems?
But back to the main problem, I think it's brake related, & not ABS related. You know rust will form on the rotors in a couple of days? It's not big deal.
Have you tried to rebed the pads? Going up to 60-80 a few times, & do a steady hard stop, NOT going into ABS. Do that a few times, till, just before fade, then drive slow, to let the cool, then park.
