| auditech79 |
Feb 26, 2007 12:47 AM |
RE: breather hose
Oh its probably the suction jet pump, its under the y pipe. You have to remove all the plastic engine overs, remove the y pipe by removing all the 10mm bolts on top of the engine and the two by the turbo inlet which you can easily see when removing the plastic covers. Once the y pipe is removed should be able to see on the right rear of the engine a plastic looking thing that has three hoses going into it, two large hoses and a small hose. While your under there you might as well check all the vaccum lines and one way check valves because they usaully are broken causing a vaccum leak. Oh and when you remove the y pipe make sure to put some shop rags into the turbo inlet so any crap doesn't fall in there.
