breather hose
Old Feb 26, 2007 | 12:31 AM
modset's Avatar
Default breather hose
can anyone tell me how to replace breather hose on 2.7t engine?
Old Feb 26, 2007 | 12:35 AM
auditech79's Avatar
Default RE: breather hose
Which hose
Old Feb 26, 2007 | 12:41 AM
modset's Avatar
the breather hose which can get clogged causing valve cover gaskets to leak. i know it is located under or behind intake manifold. where exactly that is, i don't know.
Old Feb 26, 2007 | 12:47 AM
auditech79's Avatar
Oh its probably the suction jet pump, its under the y pipe. You have to remove all the plastic engine overs, remove the y pipe by removing all the 10mm bolts on top of the engine and the two by the turbo inlet which you can easily see when removing the plastic covers. Once the y pipe is removed should be able to see on the right rear of the engine a plastic looking thing that has three hoses going into it, two large hoses and a small hose. While your under there you might as well check all the vaccum lines and one way check valves because they usaully are broken causing a vaccum leak. Oh and when you remove the y pipe make sure to put some shop rags into the turbo inlet so any crap doesn't fall in there.
SSEI173
May 25, 2014 04:31 PM
bmob222
Aug 30, 2013 03:05 AM
AudimaniaA4
Jan 26, 2008 09:17 PM
bontyal
Feb 23, 2006 04:03 PM
