Broken Pinch bolt- urgent advice needed
Old Feb 19, 2008 | 02:38 PM
nemohm's Avatar
Default Broken Pinch bolt- urgent advice needed
Disassembling the front suspension components for axle cv boot replacement:
The pinch bolt (wheel bearing hub to upper control arms) got broken (despite days of penetrating oils soaking).
Does anybody know what material (alloy) is the bolt made from? (Does not seem to be from steel).
Heating the housing did not help so far
Is the drilling the only option to get the bolt out?
Old Feb 19, 2008 | 02:49 PM
spudzwudz's Avatar
Default RE: Broken Pinch bolt- urgent advice needed
if you do need to drill, use left handed drill bit's, alot of time the bit will grab and pull out the bolt. For this to work you need a stout drill!! No cheap battery operated drill.
Old Feb 19, 2008 | 03:54 PM
Yentemad's Avatar
either a left handed drill bit as stated before would work, or an "easy-out" (its kinda a square rod with a hex bit on the end of it if you've never seen one) works real well sometimes. you just need to drill a small hole then hammer it into the hole you made(you need a good hammer) and with a bit of luck you can unscrew the bolt like that, but if you have bad luck the easyout will just round out the hole you hammered it into, or worse the easyout can break inside the hole... you do not want to have to drill out that metal on the easyout...
Old Feb 19, 2008 | 04:16 PM
spudzwudz's Avatar
if you use an "easy out" make sure to apply constant steady pressure. th easy out id made of much harder metal then the bolt, and their a pian to drill out if one breaks. When i use one i get my T-handle on, then a breaker bar and slowly add pressure untill the bolt comes lose.
hartsoe1
Dec 7, 2012 11:22 AM
vgo
Aug 1, 2012 10:04 PM
Aud1A4
Jan 16, 2011 03:42 PM
legendpilot
Mar 12, 2009 08:57 AM
Paco
Dec 22, 2006 03:03 AM
