check engine light is on
Old Mar 14, 2007 | 10:06 PM
S4LIFE's Avatar
Default check engine light is on
i have a 2000 s4 and the check engine light is on. i have no idea whats wrong with the car because its running just fine. i want to bring it to the audi dealership but they are charging me 180 just for a check up. anyone got some good advice of what i should dooranyone in the bay area that can help me out with the problem or know a shop that can? thanks
Old Mar 15, 2007 | 12:16 AM
2k S4's Avatar
Default RE: check engine light is on
Find some one local with a Vag-com, or go to most any autoparts stores & have them read the codes.
Old Mar 15, 2007 | 12:30 AM
joserv80's Avatar
I know auto zonehas code readers, you just need to shell out the 150 dollar deposit but you get it back when you return it...you can also check craigs list, there some guys that can check if for you for like 20 bucks.
Old Mar 15, 2007 | 01:22 AM
cary12's Avatar
Auto Zone will run the codes for you. You don't have to put any deposit down to take the VAG with you. When you get the codes, post them and you can get some help.
Old Mar 15, 2007 | 04:46 AM
S4LIFE's Avatar
i got the reading awhile ago and the tech told me that it was random misfiring. so i changed the spark plugs and he told me it had to be the ignition coil. the problem here is that i called audi dealer and they told me that if it was the ignition coil the engine light would be flashing. im going to go get an OBD reading again tomorrow hoping i could fix this problem.
Old Mar 15, 2007 | 07:05 AM
gododgers05's Avatar
Just go on ebay and buy yourself an obd2 scanner their only like $60 shipped, and believe me its a good investment...http://cgi.ebay.com/ebaymotors/PROFE...95130176QQrdZ1
Old Mar 15, 2007 | 05:54 PM
CRAZYHAWK's Avatar
Or one of these for around $40.
http://search.stores.ebay.com/OneSma...readerQQsofpZ0
Old Mar 15, 2007 | 06:30 PM
2k S4's Avatar
If you own a S4 & want to work on it your self. Ponny up & purchase a REAL Vag-com. It will pay for it self with only a couple of uses.
Old Mar 17, 2007 | 08:29 PM
mtm584's Avatar
The dealership may have told you a little bit of a story. The coil could still be the problem. The only way it flashes is if there is a type 1 misfire which is when a cylinder is dumping a lot of HC's into the exhaust After you installed the plugs did you did clear the codes right. What kind of plugs did yo uuse?
Old Mar 17, 2007 | 11:50 PM
senecak19's Avatar
This may be stupid, but my car was a faulty gas cap.
