Crack in Coolant Expansion Tank possibly causing P1296?
Old Sep 28, 2006 | 12:25 AM
BirdLips's Avatar
Default Crack in Coolant Expansion Tank possibly causing P1296?
My engine light came on today and the code is P1296. I did a general scan of the engine to make sure the TBB and other hoses were attached. I noticed a crack in the Coolant Expansion Tank with a very small amount leaking. I am wondering if this crack is allowing air into the cooling system causing the P1296? (Before I go out and buy the coolant temp sensor and 02 sensor). If not would the CTS and 02S replacement fix it?
Also, I will have to replace the Expansion Tank regardless now and would appreciate any advice as to where a good place to pick up a new one would be.
Thanks in advance!
hxgaser
Aug 18, 2013 11:18 AM
jonbonesjones
Nov 23, 2011 10:42 AM
grkerr
Feb 8, 2011 04:23 PM
Trey25
Feb 29, 2008 01:09 AM
hyland
Oct 2, 2007 01:05 PM
