data stream/vag com
Old Mar 1, 2006 | 10:27 AM
kakarot's Avatar
Default data stream/vag com
I dont want to use a 250 buck vag come only ones, so I would like to know what data stream type is our cars. Particullary mine. and if posible the order of info. like RPM, temp, ign, etc.... that I would get from desifering the data stream.
Tnx, also I'm a programmer.
Old Mar 1, 2006 | 04:27 PM
kakarot's Avatar
Default RE: data stream/vag com
I wont share with a program if you wont share with the data. :-)
Old Mar 5, 2006 | 06:28 PM
dankhound's Avatar
Your probably asking in the wrong forumn. Now body here has the ability to decode(a good chunk of the datas encoded) and then decompress the data to find out exactly what it means. Thats why everyone uses some sort of aftermarket scan tool.
Old Mar 5, 2006 | 09:36 PM
kakarot's Avatar
hmm good point
then I just make a vag cable out of CAT 5 wire and use freeware program from roos tech, that should be enough
Old Mar 8, 2006 | 12:31 AM
dankhound's Avatar
Im sure everyone here would be interested in a writeup on how to make theyre own cable. Or even a place to buy them from our resident computer expert. Just a thought, if you find the extra time.
Old Mar 8, 2006 | 10:32 AM
kakarot's Avatar
it not as like ross tech, even though I know how to make one, its simple.
get cat 5 cable splice some, and I will test as say. later on.
Old Mar 17, 2006 | 05:28 AM
Jeremy@ConceptDub's Avatar
You can just buy a cheaper cable and use ross-tech software??? Why make your own??
Old Mar 17, 2006 | 03:49 PM
kakarot's Avatar
well that cheap wire is easy to make.
ah I saw it somewhere.
now you making me search for a print out [sm=devilgrin.gif]
Okey found it now evrything is a mess,
here
orange & white/orange red +12
Brown & white/Brown Blue K
Blue & white/Green Black GND
Green * White/Blue Yellow L
link if works.
http://www.audifans.com/pipermail/s-...er/008156.html
another thing is a vag com
wont type but this is it:
http://www.planetfall.com/~jeff/obdii/
EDIT wow links actually work well anywho I never tried them but gona build the vag com just becouse I'm cheap and have nothing to do at home, nobody to scream at me, not married. Oh welll
Old Mar 23, 2006 | 12:07 AM
Jestnomen's Avatar
6th Gear
Let us know how your project goes. I think it would be kinda fun to build my own Vag-com.
tfakhouri
Nov 10, 2013 01:10 PM
fusionknight
B8 Models
Jan 17, 2012 02:54 PM
rupz
Dec 19, 2006 06:59 PM
