does K&N filter oil contaminate the MAF sensor?
any downsides to using K&N? does it filter out dust as good as the paper filters?
RE: does K&N filter oil contaminate the MAF sensor?
If you over oil the k&n it will contaminate the maf. there is a post somewhere in af that a comparison was done between the k&n and a high quality paper filter and the difference was very minimal.
do a search on air filters to see if you ca find it. |
hmm..if there's little improvement in airflow, i think i'll just stick to the oem filters.
how much oil is too much? i have a k&n and my engine revs fast so the air flow must be better...it also sounds good:)
That might be justbecause you put a newer filter in and clean it often, or it could be the filter, my mechanic told me to stick with oem ones because they've had a lot of problems with them before. K&N are sweet for American and Japanease cars, but don't do much for Audi's
I was told that the oil from a K&N right out of the box will harm the MAF
When you clean it, make sure there is nothing dripping off. You can hook your garage vacuum up to it, & make sure there is no loose oil.
Or just switch to a foam filter that uses a much higher viscosity oil. |
from whwat ive read, if you blot it pretty good with some papertowels it should be okay. as long as its not excessively oiled, itll be ok
