does K&N filter oil contaminate the MAF sensor?
Old Jul 25, 2007 | 11:14 AM
esandes's Avatar
Banned
Default does K&N filter oil contaminate the MAF sensor?
any downsides to using K&N? does it filter out dust as good as the paper filters?
Old Jul 25, 2007 | 11:29 AM
beefski's Avatar
Default RE: does K&N filter oil contaminate the MAF sensor?
If you over oil the k&n it will contaminate the maf. there is a post somewhere in af that a comparison was done between the k&n and a high quality paper filter and the difference was very minimal.
do a search on air filters to see if you ca find it.
Old Jul 25, 2007 | 12:55 PM
esandes's Avatar
Banned
hmm..if there's little improvement in airflow, i think i'll just stick to the oem filters.
Old Jul 27, 2007 | 05:06 AM
pimptrooper3000's Avatar
how much oil is too much? i have a k&n and my engine revs fast so the air flow must be better...it also sounds good
Old Jul 27, 2007 | 12:23 PM
spamilton1's Avatar
That might be justbecause you put a newer filter in and clean it often, or it could be the filter, my mechanic told me to stick with oem ones because they've had a lot of problems with them before. K&N are sweet for American and Japanease cars, but don't do much for Audi's
Old Jul 30, 2007 | 06:17 PM
cbdsm95gst's Avatar
I was told that the oil from a K&N right out of the box will harm the MAF
Old Jul 30, 2007 | 08:14 PM
2k S4's Avatar
When you clean it, make sure there is nothing dripping off. You can hook your garage vacuum up to it, & make sure there is no loose oil.
Or just switch to a foam filter that uses a much higher viscosity oil.
Old Aug 6, 2007 | 09:17 AM
votblindub's Avatar
from whwat ive read, if you blot it pretty good with some papertowels it should be okay. as long as its not excessively oiled, itll be ok
A4 Jed
Jun 23, 2013 06:13 PM
elburko91
Mar 22, 2011 07:27 PM
Niclipse
Feb 9, 2009 01:39 AM
bmwtoaudi
Jun 8, 2007 05:22 PM
