Dual Exhaust A4
Old Jan 18, 2007 | 10:33 PM
Legitballer's Avatar
Default Dual Exhaust A4
I have a 99 A4 Quattro I was wondering if it's possible to make it dual exhaust... buy 2 cats or something... but I know that catalytic converters have the O2 sensors on them so where would I connect the other sensors to? Anyreplies would be good. thanks
Old Jan 19, 2007 | 01:10 AM
kakarot's Avatar
Default RE: Dual Exhaust A4
just get a high flow cat. and split the flow after the cat. That be easier.
Old Jan 19, 2007 | 03:05 AM
SAudi's Avatar
Im assuming you have a single pipe 1.8t, well you could splice the O2 sensors or just have a single pipe and then get a y-pipe from the catback.
Old Jan 19, 2007 | 03:19 PM
2k S4's Avatar
Where do you want the dual exhaust to start? Do you want the dual mufflers like the B6?
Or do you want a full dual exhaust like the S4?
On the 1.8, it doesn't make sense to have a full dual exhaust sense there is only 1 outlet off the turbo.
If you want 2 mufflers, that's not that hard. Just cut the exhaust pipe AFTER the cat, weld in a Y pipe & route the other muffler.
There is no need on a 1.8t to have 2 cats. If you did, you would NOT need to put in another O2, since the car is not set up for it.
You can put a WBO2 in there for YOUR tuning use.
Old Jan 19, 2007 | 04:23 PM
tcuphigam's Avatar
I have a 02 a4, and am having an rattle from my exhaust at high rpm's, and when idleing after I have been driving for a bit. I was told by an exhaust guy that the batts in the cats are breaking up, and should be replaced by the dealer. Does anyone know more about this? Or is there a simpler solution or upgrade I should do instead?
AudiA632
Mar 21, 2012 01:33 AM
EnviedA6
Aug 30, 2007 02:25 PM
kgsolomon1
Oct 3, 2006 03:28 PM
ukranjah
Mar 2, 2006 04:41 AM
David_K
Apr 9, 2005 12:59 AM
