ECU
When you say reset I prosume you mean erase lernt values e.g your style of driving is recorded do you only like to use half the throttle and pull away slowly or use full throttle and have the car being responsive. To erase the values you need diagnostics and you go into engine 01
adaption 10
channel 00
This will erase the learnt values inthe engine control unit if your car is multitronic it is also worth erasing the learnt values in the gearbox same procedure but you go into
gearbox 03
Once you have erased the learnt values race your car about for the next 15 min and it will store your new style of driving and make a more responsive engine and gearbox.
adaption 10
channel 00
gearbox 03
Well I used to reset my ecu all the time in the tubby by yanking the fuse out. It was even labelled as such on the fuse cover. The ecu is obviously electronic, so there must be a certain fuse you can pull, for 30 seconds, or an hour, or so, to reset the bugger...
