Engine working temperature??
Old Jun 8, 2007 | 12:49 PM
j4n3k's Avatar
Default Engine working temperature??
Ok here is the question. What is the normal working temperature for an audi 100, 2.3e (1992) When i drive my temperature is normal 90. But when i stand in traffic it goes to allmost 100. I gess around 95 or a litlle more. My fan is running so i wonder is this normal?
Old Jun 8, 2007 | 02:02 PM
GeilKyle2's Avatar
Default RE: Engine working temperature??
from what I see, fan on temp sensors are around 92-95, thermostats are around 87. You seem to be within your temperature ranges alright
Old Jun 9, 2007 | 01:53 PM
j4n3k's Avatar
So thers nothing wrong? And i cant hurt the engine? this fans have 2 stages for speed right so i was wondering maybe the second stage dont work.
Old Jun 11, 2007 | 09:59 AM
GeilKyle2's Avatar
as long as it's not going over 100 and you have a fan coming on. Find out for sure if you have 2 fan speeds, and test the circuits if you feel the one is not working
Old Jun 11, 2007 | 02:32 PM
j4n3k's Avatar
mhm. Its not going over 100. So how do i check the speeds of the fan. I know that the fan speeds up when the car is hot and you add gas. So does this mean that is working ok?
Old Jun 12, 2007 | 12:20 PM
GeilKyle2's Avatar
Oh, nm I wasn't aware are you car had a viscious fan, that fan will vary with heat. Is your electric fan working?
Old Jun 12, 2007 | 01:19 PM
j4n3k's Avatar
Yes i think it works. Yes its a viscius fan so what does this change?
Old Jun 13, 2007 | 11:07 AM
GeilKyle2's Avatar
viscious fan is controlled all by itself, no electronics required there. The viscious fan should be the only one used most of the time and electrical aux is kinda a backup. As long as both of your fans are working properly, and based on the temps your giving me, i don't think you have a problem. What position are the numbers on the gauge in? what number is in the middle?
Old Jun 15, 2007 | 12:32 PM
j4n3k's Avatar
90 is positioned litlle to the left, so in the middle i would gess its around 95 and then slightly to the right is 100.
Old Jun 15, 2007 | 12:34 PM
GeilKyle2's Avatar
a cars temp gauge is pretty much set up to run in the middle, so alittle either way and your alright
