Erratic Cruise Control Function
Old Mar 23, 2005 | 11:07 AM
rstraub2's Avatar
Default Erratic Cruise Control Function
I'm hoping somebody else out there has had similar symptoms, and can point me in the right direction. My cruise control only works in the morning for about 5 to 10 minutes. While it's working, it works well, (i.e. maintains speed, resume works, brake and clutch disengage features work, set button works, etc.), but only for 5 to 10 minutes. After that, it stops working at all until the following morning when I go to work. I checked the brake and clutch vent switches, and they function correctly. I gambled and replaced the multi-function switch on the steering collumn, and that did not change the problem. I checked for vacuum leaks, and couldn't find any. Anybody have a problem like this? If so, how did you resolve it? Any other things to try? Thanks.
Old Mar 24, 2005 | 01:16 AM
macky2114's Avatar
Default RE: Erratic Cruise Control Function
i have the same problem haven't gotten it fixed yet but i changed the fuses which mine was burned, i thought mabe it shorted it out or something but i should be getting that look at pritty soon.
chooch628
Sep 5, 2007 03:32 AM
JDriver2
Jul 10, 2006 11:16 PM
A4 the Quattro
Mar 16, 2006 07:07 PM
