ESP and Check Engine at the same time.
Old Dec 8, 2015 | 10:56 PM
Chavarria16's Avatar
Default ESP and Check Engine at the same time.
Today i was coming home in my audi A4 2.0T 2006, and suddenly the ESP and Check Engine lights went on , the car continued normally worked the next 20 minutes late I get home , the ESP light was turned on and then turned off , then come back on until both were lit permanently .
contribution or any idea of ​​what is happening ?
Old Dec 9, 2015 | 09:19 AM
dave944's Avatar
Get the OBD codes from the car and post them here.
Old Dec 13, 2015 | 01:41 PM
SFL_A4's Avatar
You need to get the fault codes. Go to any Napa, Autozone or similar shops, they will lend you their OBD scanner for free. Check the codes and report back what you find. Chances are you may be experiencing the cam follower problem. Have you ever had it checked? On my 2006 with 100k miles it had worn through the cam follower and then started to eat the fuel pump plunger. Thankfully Audi repaired it under extended warranty at no cost to me.
Old Dec 13, 2015 | 06:48 PM
dave944's Avatar
Fuel pump plunger? On an EFI engine?
Trance08
Jun 8, 2010 05:19 PM
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
jhsteel82
Dec 16, 2008 12:16 PM
sirswank
Feb 7, 2008 06:38 PM
