Flashing Red Light On - On Dashboard!
Old Oct 31, 2005 | 02:40 AM
pauldavis1234's Avatar
Default Flashing Red Light On - On Dashboard!
Hello,
I have a 98 A4 Tdi with 90K on the clock. Recently, a flashing red light (water with thermostat in it) comes on when the engine is warmed up - after about 10mins. When I inspect the coolant reservoir - it is full and a orange color. The temp remains in the middle at 90.
History:
Red light came on, upon inspection - reservior was empty - filled up with 50/50 normal coolant & water.
About two months later - same thing happened - again filled up with coolant & water.
Now - the light comes on - but the coolant level is up to the top!!
Has anyone else come across this or something similar?? Please help!!
Thnx,
A Novice!
Old Oct 31, 2005 | 08:25 PM
Jestnomen's Avatar
6th Gear
Default RE: Flashing Red Light On - On Dashboard!
Maybe a bad coolant level sensor at the bottom of the reservoir?
Old Nov 1, 2005 | 01:36 AM
Thanks!!
Will give it a go! Do you happen to know if its hard to get to replace or expensive?????
Old Nov 1, 2005 | 04:33 AM
flyboy's Avatar
thats what I was thinking.
Old Nov 1, 2005 | 10:26 PM
BaconBait's Avatar
ORIGINAL: pauldavis1234
History:
Wait a sec... you filled the reservior and it was empty 2 months later?
You may have a more serious problem than a faulty sensor.
Old Nov 1, 2005 | 10:58 PM
flyboy's Avatar
Yeahbut, I've seen the senser go bad and the coolant leak though the sensor, not the o ring but the sensor.
Old Nov 2, 2005 | 12:20 AM
Thanks Guys - great inputs!
Yes, correct reservoir was empty after approx 2 months.
I am getting a quote from a dealer on Thursday for a new sensor and replacement - and will keep you posted.
Interesting to know the coolant may also leak through the sensor - as this may be whats causing it to go bad!
Also, it only happens about 75% of the time I'm driving and only when the engine is warmed up after about 10mins
Thnx,
Paul
KEYAZ
May 27, 2016 06:30 AM
Don Ali C
Feb 28, 2013 10:16 AM
dormina123
Jun 4, 2012 07:28 PM
Ian Hunt01
Nov 11, 2007 12:39 PM
skibum0019
Oct 5, 2004 01:38 PM
