View Poll Results: A poll
Shell V Power
28.57%
Sunoco 94
11.90%
Sunoco 93
7.14%
Amoco/BP Premium
7.14%
Mobil Premium
14.29%
Marathon Premium
0%
Chevron Premium
19.05%
I don't care, whatever is cheapest.
11.90%
Voters: 42. You may not vote on this poll
Which fuel do you use?
Old Nov 3, 2004 | 10:42 AM
Jestnomen's Avatar
6th Gear
Default RE: Which fuel do you use?
ORIGINAL: CRAZYHAWK
I feel no difference from 93 to 89.
you're not going to. but your engine does.
Old Nov 3, 2004 | 11:03 AM
CRAZYHAWK's Avatar
So far I have 72,000 mi without any problems. I'm going to add Gumout Regane to my gas before my next fillup.
Old Nov 3, 2004 | 03:17 PM
David_K's Avatar
if your not chipped then it shouldnt matter what octane you use. especially if you have a v6. the sudi v6 can run fine with 87 octane because it doesnt require the knock protechtion that turbo cars do
Old Nov 3, 2004 | 04:36 PM
Jestnomen's Avatar
6th Gear
I've never heard that V6's don't need 91+. Not sure if I buy that.
Old Nov 3, 2004 | 07:13 PM
CRAZYHAWK's Avatar
Mine is a 2001 1.8t Q. 89 is fine.
Old Nov 3, 2004 | 08:00 PM
audiboy1618's Avatar
Fine that you can notice.. pop the hood and look around pal
Old Nov 3, 2004 | 09:16 PM
CRAZYHAWK's Avatar
What am I looking for, audiboy 1618 ?
Old Nov 3, 2004 | 09:26 PM
  #18
Look at your combustion chamber, the lower octane gas combust to fast.It will ruin your spark plugs. And its not good for your cat and o2 sensor.You will be paying the differnce in repairs useing 89. But hey, dont take our word for it, you'll find out soon enough.
btw- flip your gas tank lid open and read, if you still think 89 is ok
Old Nov 4, 2004 | 01:03 AM
  #19
Doose's Avatar
On an unchipped 1.8t the ECU can retard the timing somewhat in response to the use of lower octane fuel. The problem, as I see it, is this. With the requirement from Audi that we use at least 91 octane fuel, the engine is tuned such that the timing is advanced to provide higher performance. By using a lower octane fuel you are doing two things. One, the lower octane fuel combusts too soon so you are dumping unburned fuel into your cat and over your 02 sensors. Two, the ECU, sensing the early combustion (knock), retards the timing and lowers the overall performance of the engine. Also keep in mind that when your ECU retards the timing in response to knock it also curtails the amount of boost your turbo produces which defeats the purpose of the engine design in the first place. JMHO
Old Nov 4, 2004 | 01:12 AM
  #20
David_K's Avatar
ORIGINAL: Jestnomen
Well now you have heard it
