Gas
I am an owner of a 1995 audi S6 it has a 5cyl 2.2l turbo, i was traveling down the highway today, it is a trip i take all the time but this time i knoticed i used ALOT more gas than i ushually do.......what does this mean and what can i do.. thanx
Richard
Richard
it could be a number fo things, you could need a tune up, a sensor could have failed, clogged fuel filter. tell us of anything else that seems out of wack for example a temp gauge that keeps on cold or variates could mean the ECT went out making the car use more fuel. also when did you last change the air filter. BTW before anyone says run a vag for codes remember hes OBD1.
that could possibly it since turbos get more power with less gas. if you have a turbo problem it could be very muich it. but first make sure the turbo is the problem also how much MPGs did you get before and how much are you getting now.
Hey i am thinking it is the turbo cause i am not getting alot or maybe no boost out of it, so that being the case.....what kind of turbo is in the 1995 audi S6 5Cyl 2.2l, like i said i am cluless when it comes to this stuff and I thank you for all your help so far
thanx again
Richard
thanx again
Richard
what do you really think could be wrong with the turbo? is it overheating? smoking? making noise? .... i think if it is actually turbo related it could possible be the DV. how many miles on the car and have you ever replaced the DV before?
but to be honest i don't think your prob. has anything to do with the turbo system... i am leaning towards a MAF sensor..... or something along those lines that when it sees a problem it starts to make the car go into a limp mode.....
no codes???
no codes???
Yes the turbo does smoke quite a bit and there are alot of miles on the car and i just bought the car out of the US so i am not even shure what has been replaces on the car i dont know that i am not getting Near as much boost out of that turbo and my gas milage is horrible, so any tips or hints you hav will be usefull, remember to be specific with me i dont know a heck of alot about cars so thanx
Richard
Richard
Ok
i hav decided that i am going to park this car and put some money under the hood!!! so if anywon has ANY ideas for me then let me know what would be good investments!!!!!!
it is a 1995 Audi S6 5Cyl 2.2 l turbo it does hav a few miles on it (135000) so even let me know if you hink it would even be worth it......................let me know!!!!!!
thanx for your help
Richard
thanx for your help
Richard
ORIGINAL: JETSPEED333
no codes???
no codes???
