Help ... 06 A4 Sputtering
Old Nov 9, 2008 | 01:37 PM
movala4's Avatar
Member
Unhappy Help ... 06 A4 Sputtering
i have no idea what going on with my car. i started the car lastnight and in started to sputter. when i step on the gas it literally feels like its going to die. the check engine light is flashing. i appreciate all the help and suggestions u guys can give me. im debating taking it to the dealer, but i am out of warranty by a few thousand miles.
Robbie
Old Nov 9, 2008 | 05:21 PM
CRAZYHAWK's Avatar
Don't drive with a flashing CEL. It probably is
a misfire which will overheat the CAT.
If you're under warranty, have the dealer tow
it in.
Old Nov 9, 2008 | 05:30 PM
movala4's Avatar
Member
any idea on how much this will run me, out of warranty. or can DIY ?
Old Nov 10, 2008 | 09:31 AM
CRAZYHAWK's Avatar
First replace the spark plugs. If that doesn't work,
replace the ignition coils.
Good luck.
Old Nov 13, 2008 | 09:07 PM
mott6904's Avatar
I would recomend replacing the spark plugs but dont just go replacing coils. Do some sort of diag. to see if its the ignitor or a coil. check for codes and that will lead you to which cylinders to start with.
Old Nov 13, 2008 | 09:11 PM
movala4's Avatar
Member
Talking
I appreciate the help guys ... Turns out that it was a coil. I changed all four and replaced my plugs.
Shes a happy camper again
rmr1499
Jul 20, 2014 03:00 PM
arc11
Sep 12, 2011 12:32 AM
BeauA4
Nov 29, 2008 04:05 PM
cfrench
Nov 21, 2008 10:12 PM
Jaxter
Oct 9, 2008 08:53 PM
