HELP?????????????????????????
Old Apr 29, 2007 | 02:23 PM
lucky123's Avatar
Default HELP?????????????????????????
anyone has changed serpentine belt on a a4 3.0L???
Old Apr 29, 2007 | 04:39 PM
techbod's Avatar
Default RE: HELP?????????????????????????
the tension is spring loaded put a spanner on it to take the tension off ( T ) being the tensioner
[IMG]local://upfiles/12092/2EA11E65720E43F9AFE600B8A2D56F76.jpg[/IMG]
Old Apr 29, 2007 | 09:47 PM
lucky123's Avatar
Thanks. I'm going 2 try this now.
Old Apr 29, 2007 | 10:04 PM
lucky123's Avatar
Do you have all the installtion instruction for this job, I seem to haveing a problem putting the belt back on and releasing the tension.
Old May 1, 2007 | 02:08 AM
SAudi's Avatar
well if its anything like the 2.8 then all you have to do is get a 17mm socket and twist down the tensioner to loosen the belt then just pull it off and put on the new one.
