Help with B7 S4 please
Hey everyone been working on an issue with my s4 that I can't seem to solve. It is an 05.5 B7 S4 with 120k miles. A couple weeks ago I left my house and stopped down the street at the gas station. I had let the car run for 5-10 minutes before driving because i hadn't driven it all week and it was very cold here. It started and run fine here but once I got gas and started the car back up I could immediately tell it was misfiring badly and had a flashing cel pop up. The car is completely cat less so very easy to tell the difference in exhaust note besides other symptoms. Luckily I was right down the street (literally about a quarter mile from my driveway is the gas station I was at) so I limped home barely touching the gas and shut her off. We scanned the car with a generic obd 2 scanner (non vagcom) and found misfires in cylinders 1, 2, 3, and 4. Car was due for plugs and a new air filter so went ahead and did that hoping the plugs would fix the problem. I used ngk 3199 plugs as directly by local dealer supplier. Did them all correctly etc and then started the car. Same symptoms but still random misfire code and misfires on all passenger side cylinders only. It felt like it was running a little better but still shaking slightly at idle and flashing cel. Car would not die though just kept sputtering. I listened under the hook for chain noises praying to god it wasn't a timing issue and didn't hear anything out of the ordinary (besides it running like a $2 whore). I figured the next most likely thing would be the ignition coils so ordered 4 of the updated ones from jhm and replaced all passenger side cylinders. Just started it back up and still running the same with the new coil packs in. I don't have a scanner with me right now but am just looking for some input as I'm sure we will get the same misfires from the passenger side etc when we do scan it tomorrow. I will have an actual vag com here tomorrow so I'm hoping maybe that can help me get some more info. I am not a huge mechanic but I love audis and it is killing me having her running like this. I do have an a4 as well as my daily driver so luckily I've still been able to get around. I have learned a lot from this site and really appreciate all the great knowledge on here. I'm hoping you guys can give me some input or ideas as to which direction to go from here before I have to tow it to the stealership :(
Thanks in advance guys! |
Not sure if it matters but oil and filter were just changed about 300 miles ago. Also forgot to mention we did try running the car with the maf sensor unplugged to see if that was the issue with no change.
Thats not a good sign that all the misfires are on one bank. Def be interested to see your VagCom results when you get them posted. I would do a compression test next, at least on Bank 1.
Vag com today and ill have a copy of the test results later to share but found out it was actually only misfiring in cylinder one after clearing codes. Very few misfires in cylinders 2 and 3 that could easily just be from cylinder one misfiring. No issues in cylinder four at all whatsoever now. The guy who scanned it is a former VW tech and said he is leaning more towards a bad injector now. Also found out I need a new battery today which I will replace soon (had to jump the car after running codes to get it started). It ran fine for a second or two after clearing codes and jumping it but immediately went back to misfiring in cylinder one with just a few intermittent misfires in 2 and 3 but none in 4 now at all. I will post codes later but got nothing specific except misfire codes for the 3 said cylinders now and a strange transmission limp mode code. It is a automatic 6 speed tip transmission. I was happy to see nothing serious pop up and the scan and will be more than happy with a bad injector rather than other more serious things. I also need to do my vavle cover gaskets as they are getting leaky but I don't think that's contributing to the issue and as soon as I can drive her to my buddies house ill replace those. I've seen a few issue with bad injectors but any thoughts on this guys? Maybe running some fuel cleaner if its just a dirty injector or is it more than likely in need of replacing in that cylinder. Any thoughts on this guys? Thanks in advance!
Here's the vag com scan guys, the maf sensor codes were just left over from trying to run it with it unplugged before. After clearing and rescanning it did not come back at all. Input would be valuable guys. Thanks!
Sunday,13,January,2013,14:01:39:55282 VCDS Version: Release 11.11.4 (x64) Address 01: Engine Labels: 079-910-560-BBK.lbl Control Module Part Number: 8E0 910 560 M HW: 4E0 907 560 Component and/or Version: 4.7+ V8/93 JHM G 0010 Software Coding: 0007771 Work Shop Code: WSC 06435 000 00000 VCID: 2F66D5F0BECABE6088F 8 Faults Found: 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - - MIL ON 16685 - Cylinder 1 P0301 - 001 - Misfire Detected - MIL ON 16687 - Cylinder 3 P0303 - 001 - Misfire Detected - MIL ON 16686 - Cylinder 2 P0302 - 001 - Misfire Detected - MIL ON 16544 - Oxygen (Lambda) Sensor B2 S2 P0160 - 004 - No Activity 16691 - Cylinder 7 P0307 - 001 - Misfire Detected 16486 - Mass Air Flow Sensor (G70) P0102 - 002 - Signal too Low - Intermittent 16497 - Intake Air Temp. Sensor (G42) P0113 - 002 - Signal too High - Intermittent Readiness: 0110 1101 Address 02: Auto Trans Labels: 09L-927-760.lbl Control Module Part Number: 8E0 910 156 M HW: 09L 927 156 Component and/or Version: AG6 09L 4.2L5V USA 0030 Software Coding: 0000002 Work Shop Code: WSC 06335 000 00000 VCID: 3064D68CA3F4A198915 2 Faults Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent 18111 - Limp Mode due to Control Module Reset P1703 - 000 - - Intermittent Address 03: ABS Brakes Labels: 8E0-910-517.lbl Control Module Part Number: 8E0 910 517 C HW: 8E0 614 517 BB Component and/or Version: ESP8 quattro H04 0180 Software Coding: 0004902 Work Shop Code: WSC 06335 000 00000 VCID: 27563DD0963AE62040F 2 Faults Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent Sunday,13,January,2013,14:07:07:55282 VCDS Release 11.11.4 (x64): Generic OBD2 Mode 03: Emission related fault codes Address 10 (Engine): 4 Faults Found: P0300 - Random/Multiple Cylinder Misfire Detected P0301 - Cylinder 1: Misfire Detected P0303 - Cylinder 3: Misfire Detected P0302 - Cylinder 2: Misfire Detected Mode 07: Pending emission related fault codes Address 10 (Engine): 6 Faults Found: P0300 - Random/Multiple Cylinder Misfire Detected P0301 - Cylinder 1: Misfire Detected P0303 - Cylinder 3: Misfire Detected P0302 - Cylinder 2: Misfire Detected P0160 - Oxygen (Lambda) Sensor B2 S2: No Activity P0307 - Cylinder 7: Misfire Detected Freeze Frame Data for address 10 PID02 DTC that caused freeze frame data storage: P0300 PID03 Fuel system 1/2 status: Closed loop, using O2 sensors ... Closed loop, using O2 sensors PID04 Calculated load value: 12.9 % PID05 Engine coolant temperature: 80 °C PID06 Short Term Trim - Bank 1: -17.2 % PID07 Long Term Trim - Bank 1: 0.0 % PID08 Short Term Trim - Bank 2: 25.0 % PID09 Long Term Trim - Bank 2: 1.6 % PID12 Engine RPM: 729 /min PID13 Vehicle speed: 8 km/h PID14 Ignition timing advance for cyl #1: -3.0 Degrees PID15 Intake air temperature: 3 °C PID16 Mass Air Flow: 8.02 g/s PID17 Throttle position sensor: 13.7 % PID18 Secondary Air Status: Atmosphere/off |
The misfire counter was very high for cylinder one and extremely low for 2 and 3 leading me to believe the slight misfire in those cylinders is just being caused by the major misfire in cylinder one. Didn't want you guys to think 2 and 3 were misfiring badly since they show up in the faults along with number 1 bc they did have a few misfires
Talk to a VW mechanic buddy today and he said weak signal caused by my dead 8 year old battery could be what's causing the running issues now. Codes contain weak signal from ecu so I am really hoping that's it. Any thoughts or similar experience with an old dead battery causing issue like this guys? Does anyone even get on here anymore ? Input would be greatly appreciated. I plan on getting a new battery this week.
Originally Posted by jameskatzer
(Post 1420149)
Wtf? Know I see why everyone is on Audizine, this forum sucks, everybody wants to respond to these dumbass threads people start on here but no input for an actual issue? Damn thanks guys! |
Bump! Really no input on this?
| All times are GMT -4. The time now is 03:05 AM. |
