Help with error code please
Old May 2, 2007 | 09:15 PM
JCatt9's Avatar
Default Help with error code please
Hi guys,
2001 audi a4 1.8t is running 017356 I belive . It reads long term fuel trim running too lean(bank1). any ideas on what the cause of this could be, I was thinking a bad maf?
JC
Old May 2, 2007 | 09:21 PM
CRAZYHAWK's Avatar
Default RE: Help with error code please
First check for vacuum leaks, the L and Y shaped formed hose.
Old May 7, 2007 | 02:35 PM
LampyB's Avatar
possibly a bad 02 sensor.
LampyB.
Old May 8, 2007 | 05:18 PM
JCatt9's Avatar
Hi guys,
I did have a few cracked hoses so I replaced them and then cleared the CEL. A few days later the light reappeared so Icleaned the MAF and all was good untill a few days later so I finally broke down and droped it off at Audi. They pulled the same code and told me the MAF needs to be replaced . My question now is can I run the car for a few more weeks with a bad MAF or is this really harmful?
Thanks, JC
Old May 9, 2007 | 04:32 PM
LampyB's Avatar
You can run the car with a bad maf for a few weeks. It'll just run with a significant loss of power and acceleration. when you cleaned the maf, did your car run a lot faster? when I cleaned mine, my car hauled *** afterward. if it is indeed a bad maf, when you replace it your car will run fast as hell compared to what its running right now.
LampyB.
Old May 9, 2007 | 05:01 PM
JCatt9's Avatar
Lampy,
yeah when I cleared the code the car is like 3 times faster untill the light came back on , When you cleaned your maf did you clean the connections as well? . When I did mine I just sprayed the wire about 7 times and let it sit for an hour or two, maybe i did it wrong> what do you think
thx, JC
DCAV8R
Jan 23, 2023 06:33 AM
aaceve7
Sep 7, 2012 01:08 PM
NewJ_A4
Feb 3, 2008 01:09 AM
winter001
Jan 8, 2008 07:50 PM
mikehh
Aug 25, 2006 03:35 AM
