How to compress Audi rear brake cylinder??
Old Feb 24, 2007 | 12:58 AM
haawill's Avatar
Default How to compress Audi rear brake cylinder??
1990 Audi 200 Turbo Quattro Stick Wagon – How to compress rear brake cylinder?
Does anyone know how to? I’m use to inserting a strong screwdriver or flat metal bar against the cylinder and just applying an even steady pressure and the cylinder piston moves back in so I can install new brake pads. Works fine on the front brake. On the REAR brakes what a pain! Some one told me you had to turn and push. I’ve taken the caliper off the car, set it up in a vice and with someone pressing down on the cylinder piston I’ve used pliers to turn the piston, all the while having steady pressure applied. Still NOTHING! no movement of piston. What am I doing wrong here???!1 HELP! haawill@yahoo.com
Old Feb 24, 2007 | 05:09 AM
a3square's Avatar
Member
Default RE: How to compress Audi rear brake cylinder??
You canown the tool from autozone for about $40 or own it for the same fee. It was a fairly simple using it
Old Feb 25, 2007 | 12:44 AM
blackdjone's Avatar
Whats up. I rented the tool to compress the rear brake piston and I cannot seem to get anywhere with it. What am I doing wrong? It seems pretty easy to use but I am having issues.
Old Feb 25, 2007 | 01:44 PM
CRAZYHAWK's Avatar
I had to open the bleed valve on mine.
Old Feb 25, 2007 | 01:58 PM
2k S4's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=40732
It needs to be pushed & turned at the same time
Old Feb 25, 2007 | 07:21 PM
AWDaholic's Avatar
Senior Administrator
If your rear pads are worn down too far you'll have no luck getting the tool in, to compress the piston. You will have to do it the old fashioned way, until you've created enuff room to fit teh tool in. Is that what you're having a problem with? getting it in? (I'd heard that about you)
Old Mar 9, 2007 | 03:13 PM
2007misanoREDrs4's Avatar
use a c-clamp and a block of wood, its the easiest and most effective way]
Old Mar 9, 2007 | 03:20 PM
techbod's Avatar
^^^ no way mate because of the E break
they have to be pressed in and turned at the same time just like the newer cars
http://images.google.co.uk/imgres?im...%3Den%26sa%3DN
Old Mar 9, 2007 | 04:35 PM
AWDaholic's Avatar
Dude, you're in Jersey, right?Go to Autozone, they have those in Jersey, don't they? Go up to the counter and tell them you need to rent the brake-caliper reset tool, let 'em ring it up on your Visa (or, PM me the Visa # and I'll call them, FOR YOU[&:]). WHen you bring the tool-kit back, unscathed and complete, they'll re-credit the funds to your Visa (ddon't forget to send ME the #, along with teh security code, from the back).
Or, you could go to the HarborFreight link 2k s4 provided, above, and purchase it, online...
OR, search eBay for the same tool and yu'll save yourself about $8-$12, but, it's eBay, so...
When you get your grubby l'il mitts on it PM me a contact # & I'll PERSONALLY call you & talk you through squeezing the piston back into the caliper.
OK?
Old Mar 9, 2007 | 05:03 PM
MissionCtrl's Avatar
you're the best AWDaholic
michaeltroy
Jul 3, 2015 10:34 AM
Freight_Cartel
Mar 4, 2011 02:26 PM
wtlee3
Feb 7, 2011 01:29 PM
haawill
Mar 9, 2007 03:00 PM
