How do I pull out the rear output shaft from the trans?
I need a rear output shaft for a project car that uses the quattro torsen transfer unit. Torsen says that all the rear output shafts from 88->current are the same. I'm looking at an 1988 Audi 90 Quattro in a salvage yard. Should the output shaft pop out with a pry bar, or is there more to it? I cut the drive shaft and forward part of the shaft doesn't seem to want to dissengage from the flange. I don't want to beat on it for fear of damaging it.
Thanks. |
RE: How do I pull out the rear output shaft from the trans?
you got all of the screws out that connect the driveshaft to the trans.It should just pull back and out.
