How do you change the clock on Audi A6?
Old Aug 5, 2006 | 12:43 AM
viento_a6's Avatar
Default How do you change the clock on Audi A6?
Does anyone know how to change the clock time on a 99 A6?
Old Aug 5, 2006 | 03:54 PM
iowaboostin's Avatar
Default RE: How do you change the clock on Audi A6?
No clue, this might be helpful though: On my '99 A4 there's two buttons on the gauge cluster (one resets odometer, other is right by the clock) and you simply pull that out instead of pushing in and hold it for about 3 secs and the clock will start to spin.
Old Aug 6, 2006 | 04:50 AM
dankhound's Avatar
Slightly differnt for the a6 as the clock is digital but the concept is similar. The **** on the left can be pulled. This will select the field you will be changing. You will be able to tell because it will flash. To change the number in the flashing field just turn the know left or right. Pull the know to go to the next field.
Old Aug 7, 2006 | 12:45 PM
viento_a6's Avatar
Thanks, I'll try that when I get home!
Old Sep 15, 2006 | 02:41 AM
a6xlr8s's Avatar
On the 99 a6 the clock is analog. Pull out the left reset stick and turn in the direction you want to advance. Will take several seconds to get going.
varsh
Mar 12, 2026 08:09 AM
Maynii
Mar 15, 2013 12:12 PM
toxicated555
Nov 10, 2008 11:26 PM
shift
Feb 1, 2006 02:22 AM
