How do you take a fuel pump out
Old Jan 30, 2007 | 02:05 PM
A6 Quattro V6 30V's Avatar
Member
Default How do you take a fuel pump out
[:@][sm=smiley21.gif][sm=smiley28.gif][sm=smiley35.gif][sm=smiley6.gif][sm=smiley7.gif]Guys I think my fuel pump is gone bad cause the carcut offon me when I was driving and it will start up and then cut right off after it sets then it will start and run for awhile. any ideas on what could be the problem?
I think its the fuel pump and Idont know how to take it out and replace it. Someone help me.[:@][:@][:@][:@][:@][:@][:@][:@]
Old Jan 30, 2007 | 03:35 PM
techbod's Avatar
Default RE: How do you take a fuel pump out
turn the ignition on and listen for the fuel pump to cycle for a second or two if it can be heard then its not the pump and then you need to check for fault codes
Old Jan 30, 2007 | 03:42 PM
2k S4's Avatar
You need the special tool to remove the pump, or be very careful with a drift & hammer.
Old Jan 30, 2007 | 05:32 PM
Member
what special tool is it and where can I get it from???
Old Jan 30, 2007 | 06:27 PM
2k S4's Avatar
ORIGINAL: A6 Quattro V6 30V
http://www.toolss.com/wbstore/main.a...CTMP=1&LowCt=0
Old Jan 30, 2007 | 07:02 PM
Member
can I buy this tool for any part store
Old Jan 30, 2007 | 07:30 PM
2k S4's Avatar
Don't think so.
Old Jan 30, 2007 | 07:34 PM
techbod's Avatar
I call the tools a screw driver and rubber mallet, just tap it anti clock wise
Old Jan 30, 2007 | 07:46 PM
techbod's Avatar
of course you can buy the right tool if you can afford it
Old Feb 21, 2007 | 12:39 PM
cityshark's Avatar
Be careful with the anticlockwise turning. I have an 95 A6 quattro and i was replacing fuel pump month ago. The pump didn't need ANY turning, simply pull it out. No special tool needed. Just do it with your hand. Hold the tube that goes from the pump and that's it. The gasket can be mispositioned when turning with it and reposition back is a hell of a nightmare.
Depends on a type of audi you have (and date of manufacturing i guess), 'cos i've seen various gaskets used in Audi and yes, some of those had the pump in some mysterious housings that need to be removed first. My pump was simply inserted into gasket and just two tiny plastic pins were holding the pump in place. Pulling removed the pump and inserting was the same way. No need to dismantle anything...
