indicator/blinker light not working
Old Dec 30, 2005 | 01:52 AM
a6avant's Avatar
Default indicator/blinker light not working
Hello All,
my indicator lights have slowly stopped working. they work fine when i push the hazard button, but when i go to make a turn they might blink once or not at all. at first they would stop after like 5-6 blinks but now they won't go on. Has anyone ever heard/had a similar problem. doesn't seem to be a fuse issue. the lever seems to be working fine. very frustrating.
-m
Old Dec 31, 2005 | 04:52 AM
dankhound's Avatar
Default RE: indicator/blinker light not working
Probably the hazzard switch. Its a pretty common problem.
Old Feb 14, 2006 | 03:42 AM
SideShowBobA4's Avatar
Yes i have begun to have this same issue is there an easy fix some feed back whould nice
Old Feb 14, 2006 | 02:21 PM
avanttripleloop's Avatar
i believe hazzard and indicators run off different power inputs of the relay.ie:hazzard are more power for all lights blinking,turn areless power used for only half the car. i'd change the relay.
Old Feb 14, 2006 | 03:04 PM
my book shows it is its the turn signal switch,which is run off the emergency flasher switch.
Old Feb 14, 2006 | 07:09 PM
craig_mack's Avatar
Definitely the hazard switch. $28 part, easy fix. Use angle hook set to pull out of dash..
Chris
01' 2.7T
Rhucke21
Mar 23, 2014 09:55 PM
theriles44
May 15, 2012 10:59 AM
FixOrRepairDaily
Jul 27, 2009 01:00 PM
smoovmusicdj
Apr 21, 2008 08:51 AM
zero388
Feb 2, 2008 07:03 PM
