Jerk In acceleration
Hi, just had a few questions if anybody can help.
Firstly, every time I accelerate from 0mph or 1st gear, there is a small jerk. This doesn't happen at any other time, only when the car is starting from a stopped position.
Secondly, i bought a blank remote key that matches my current A4 Fob. Where can i get it cut and programmed in NJ? No dealerships offer key cutting.
Thanks.
Thanks.
Hi there.
I can't help you with the jerk, but you might want to try calling a few local locksmiths. I know there is one in my area ( Pittsburgh ) who charges around $60 for the first key, then $5 to $10 for extras.
Hi all
i have same issue with my 2001 audi a4 b6 every time I accelerate from 0km or 1st gear, there is a jerk and it is getting worse and worse, doesn't happen at any other time, only when the car is starting from a stopped position.
can anyone help me to fix my car ??? before it makes big hol in my packet
I had the herky jerky issue too in 2006 audi a6 FWD. I bought it used and noticed it during the test drive. Got them to knock some off the sticker and took it to a independent shop. They said it was a common issue they've seen. Most likely the throttle body getting dirty. Since i was nearing a transmission fluid change. They change 5 quarts of my transmission fluid and cleaned my throttle body for free. Cost was 130 bucks. Runs smooth now.
My check engine was never on and the car never recorded an error.
Tranny flush helped. It's mainly the throttle body they said. The carbon build up. Plus on mine it's only doing it when it's cold. It is annoying and can't figure it out. Based on everyone's comment on other forums its the carbon build up on the throttle
