kind of fuels
Old 09-02-2007, 06:14 PM
zamflip's Avatar
Default kind of fuels
I just aint sure about my a4... i know it needs premium gas but my car's old owner always fill it up with regular gas... what the heck... what should i do? just stick with reg or prompt it to premium? more power?
Thanks
Old 09-03-2007, 11:16 AM
2k S4's Avatar
Default RE: kind of fuels
If you put things that are lower then the minimum requirement, the car will not like you.
Old 09-04-2007, 06:43 PM
beatnyy's Avatar
use premium. you get higher mpg with higher octane levels anyway
Old 09-04-2007, 06:47 PM
beatnyy's Avatar
and yes, you get more power. Higher octane number=more energy in the fuel, as it lets the engine run at a higher compression rate, delivering more power.
Old 09-04-2007, 07:35 PM
CRAZYHAWK's Avatar
Higher octane fuel does not have more energy. It does allow for
more boost and ignition timing advance.
Old 09-04-2007, 07:50 PM
2k S4's Avatar
ORIGINAL: CRAZYHAWK
So true, it actually has slightly less "energy". What it is, is more thermally stable. So it doesn't pre-ignite & cause a ping. This allows for more boost (F/I cars) & timing advance. On non turbo cars, you can run higher compression & get more power.
ORIGINAL:beatnyy Date 9/4/2007 3:47:37 PM
The static compression ratio can never change. What I think you meant is you can run higher boost?
Old 09-04-2007, 09:03 PM
auditech79's Avatar
ORIGINAL: 2k S4
LOL! Classic
Old 09-04-2007, 11:22 PM
David's Avatar
ORIGINAL: 2k S4
But a car can be designed (or maybe modded) with a higher compression ratio if the maker knows that they're going to require higher octane fuel.
Old 09-05-2007, 01:29 AM
SAudi's Avatar
my car says that it need premium but the minumum octane rating is 87, i assumed this is for europe, but for the short time i took 87 octane i notcied several thing, im pretty sure the car realized it was getting cheap gas and therfore retarded the timing, i had slightly less power, i would average about 250mile on a full tank with some spirited driving in a city enviornment. once i realized what i was doing, i seafoamed everything and started using premium ( always shell BTW) with that i feel more power espacially in the low RPMs and it pull alot better throughout the powerband, i know get about 300 miloe per tank with some spirited driving. all in all just use premium the 20 or cents you pay extra is really worth it.
Old 09-05-2007, 03:16 AM
JETSPEED333's Avatar
SoCal Crew Member
the octane rating determines the burn rate (of the fuel)...
depending how your engine was designed it may need a specific octane rating for the fuel used.
Quick Reply: kind of fuels
