LED tail lights, just put in, now malf. light on
Old Jul 3, 2007 | 09:07 PM
apollo_kid's Avatar
Default LED tail lights, just put in, now malf. light on
Apparently, when you addaftermarket LED tail lights (Altezza)to your car......the tail light warning light comes on because they don't draw enough power?
I guess I have to addresistors to the wires to the LED banksto fool the car.
Anyone know about this????
Old Jul 4, 2007 | 08:46 AM
jj2345's Avatar
Default RE: LED tail lights, just put in, now malf. light on
yeah,its the same with with mine
Old Jul 4, 2007 | 09:57 AM
apollo_kid's Avatar
how did you correct the problem ?
Old Jul 4, 2007 | 12:35 PM
CRAZYHAWK's Avatar
You probably will have to add resitors in parallel to draw the same power, watts.
Old Jul 4, 2007 | 01:37 PM
jj2345's Avatar
ORIGINAL: jj2345
i learned to live with it
lol
Old Jul 5, 2007 | 02:04 PM
apollo_kid's Avatar
i got some resistors today......I'll post and let you know if it works......there are a million combo's of resistors, watts vs. ohms.
im usin 10w 10ohm ones......hope it works.
Old Jul 6, 2007 | 09:47 AM
CRAZYHAWK's Avatar
Power = (Voltage X Voltage) / Resistance
Power = 144 / 10 = 14.4 watts
Good luck, it may get hot.
Old Jul 6, 2007 | 10:33 AM
apollo_kid's Avatar
i found an led resistor caculator online.........it calls for a 1 watt 100 ohm resistor on each power line to the led.....one for the parking light and one for the brake light. the bulb that was replaced by the led was only a 5 watt bulb.
let you know........
Old Jul 7, 2007 | 12:15 PM
CRAZYHAWK's Avatar
100 ohm resister will draw 1.44 watts of power across 12 volts
Power = ( E x E ) / R = 144 / 100 = 1.44 watts
Old Jul 7, 2007 | 01:38 PM
apollo_kid's Avatar
ur right.......the 1w 100 ohm did not work.......what resistor do I need?
I need to make a total of 5 watts when the parking lights are on......
The malfunction indicator does not go on when the lights are off.......the brake light does not throw the malf. light on, just the park. light....
thx for the help....
