AudiForums.com
-   General Tech (https://www.audiforums.com/forum/general-tech-50/)
-   -   Lights flashing (https://www.audiforums.com/forum/general-tech-50/lights-flashing-120460/)
smooth Dec 10, 2008 03:19 PM
Lights flashing
Hey guys, the service oil light and insp light keep flashing on the dash, oil was only done and 2 weeks ago the insp light has come on, the car is running perfect with nothing wrong at all, does anyone here know how to turn these lights off. Any help is appreciated
jangalang Dec 10, 2008 06:57 PM
what car? im lookin for the same solution
smooth Dec 11, 2008 01:39 PM
It's an Audi A4 B5 98, they are driving me nuts, the car is perfect yet these lights keep buggin me
rplets15 Dec 11, 2008 03:03 PM
well easy was is to disconnect the battery but depending on ur car that may or may not put ur radio in safe mode and then you will need a code for that but if you have disconnected it before and it was fine then do that again, uhm other solutions is a vag-com and i think there is a way to hold down the reset button on the winshield wiper stick and left button by ur speedometer
WolfsA62.8Q Dec 12, 2008 11:00 PM
Not sure on A4, but for A6 the SRI (service reminder interval) can be reset with VAG-Com tool, or using the buttons on the instrument cluster.
On an '00 - '02 A6, as per Bentley :
1. press and hold down the odometer reset button
2. turn on ignition while holding the button in, OIL appears in display
3. release trip odo button, pull clock reset button out until " --- " appears in display
4. press trip odo reset button in again, for next service event, release trip odo reset button
5. " INSP" appears in display
6. pull clock reset button until "INSP" is reset and " ---" appears in display
7. turn ignition off.. done
Or refer to your owner's manual
smooth Dec 13, 2008 05:11 PM
thanks guys, will give that a try and let you know if it was a success, thanx again
