locked out of my a3 2.0 tdi 04
Ok i hope ive posted in the right place as im new
i recently bought an audi a3 2.0tdi 2004 plate and had nothing but problems as the seller hid lots from me, my main problem at the moment is im locked out of the car the other morning the car wouldnt start asif there wasnt enough power in the battery, so i decided to use a taxi, i come home and the battery mustve completely died so the central locking wouldnt open the car, the key will also not work in the door ive been told maybe its deadlocked? so after getting breakdown serives out to me they couldnt get in it either, i had someone use a car break-in wire through the top of the window and hook the door lever but it still will not open, so he then hooked the bonnet catch so at least i could get to the battery a new working battery has now been fitted and but still the locking will not open and the key will still not work and im out of ideas, there is a possibility the battery shorted something as it was fitted as it sparked real bad? im new to cars soo any help would be good, i live in walsall also so if anybody knows a good audi local mechanic that could help me out ? many thanks |
How did you fix it
Originally Posted by Josh Matthew Williams
(Post 1410440)
i recently bought an audi a3 2.0tdi 2004 plate and had nothing but problems as the seller hid lots from me, my main problem at the moment is im locked out of the car the other morning the car wouldnt start asif there wasnt enough power in the battery, so i decided to use a taxi, i come home and the battery mustve completely died so the central locking wouldnt open the car, the key will also not work in the door ive been told maybe its deadlocked? so after getting breakdown serives out to me they couldnt get in it either, i had someone use a car break-in wire through the top of the window and hook the door lever but it still will not open, so he then hooked the bonnet catch so at least i could get to the battery a new working battery has now been fitted and but still the locking will not open and the key will still not work and im out of ideas, there is a possibility the battery shorted something as it was fitted as it sparked real bad? im new to cars soo any help would be good, i live in walsall also so if anybody knows a good audi local mechanic that could help me out ? many thanks HHI WHAT SID YOU DO. I have the same problem |
Did you fix it
I have the same problem.
