Misfire Help ???
I have a 2001 A6 w/a 4.2L (50k miles)
I get the following codes: multiple misfire misfire cyl 5 misfire cyl 6 misfire cyl 7 misfire cyl 8 Also an oxygen sensor range error from the same bank. Probably a result of the misfire. It's Not likely all the coil packs died at the same time so I though it was a cam position sensor. I replaced the cam position sensor but haven't had any change. I know ignition control modules are a problem on a lot of Audis but the 4.2 does not have one. Any other suggestions? Thanks! |
| All times are GMT -4. The time now is 07:42 AM. |
