Misfire Help ???
Old Aug 4, 2008 | 04:14 PM
cojo428's Avatar
Exclamation Misfire Help ???
I have a 2001 A6 w/a 4.2L (50k miles)
I get the following codes:
multiple misfire
misfire cyl 5
misfire cyl 6
misfire cyl 7
misfire cyl 8
Also an oxygen sensor range error from the same bank. Probably a result of the misfire. It's Not likely all the coil packs died at the same time so I though it was a cam position sensor. I replaced the cam position sensor but haven't had any change. I know ignition control modules are a problem on a lot of Audis but the 4.2 does not have one.
Any other suggestions?
Thanks!
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
