Is my water pump done for?
Old May 19, 2011 | 08:50 PM
qmoorman's Avatar
Default Is my water pump done for?
I'll try to keep it short and sweet:
I purchased my 96 A6 (2.8) about a year and a half ago. The issue that I'm experiencing is this: while driving, the red coolant light will flash (sometimes with no sound). Once it does this, I immediately pull over to see if the reservoir is full. If, it's empty, I refill it with either coolant, or water. However, recently, I've checked the level, and it has been at the correct level! After I allow the engine to cool down, I untwist the reservoir cap and the strangest thing occurs: the coolant level will sink to the point that it appears empty, then it will rise back up. It does this for about a minute. If the action stops with the level at the normal level, I'll continue to drive. After continuing to drive for a few miles, the light flashes again and the reservoir will be completely empty. This is quite puzzling.
If it is the water pump, I know that's a tricky fix. I have no plans on doing it myself. Any tips or feedback will be appreciated.
clowninmd
S4
May 30, 2013 10:47 PM
MetalMan
Jul 19, 2012 09:15 PM
josh_easlon
Feb 24, 2010 04:32 PM
AUDIFIELD
Oct 28, 2009 03:20 PM
guru_king423
May 20, 2008 08:21 PM
