Need help, im retarted.
My dad recently gave me his 1997 Audi A8 in the winter he lost control and hit a tree, no serious damage, just raidator a/c condenser and the bumper cover, my problem is the car sat for quite a while without being started and now the battery is dead, i cant locate the jump point or open the trunk, what should i do to get the car started?
jake
jake
i dont know if the key hole is jambed in the back but all i can do is push it in, which should release the latch, unless its locked, and i believe the only reason i cant unlock it is because its all power locks...i dont know, im not too smart when it comes to audis, all i know is that this is a hot car and i love to drive it... and as for the jump points being under the hood i contacted my local audi dealer and they said the same thing, either infront of the firewall under the plastic covers, or behind the radiator support, and i looked for them but to no avail i found no points...HELP PLEASE !!
as far as the trunk goes, can you turn the key in the trunk lock?
power should not matter, the key is unlocking the trunk.
whay about the keyless entry remote, the locking systems are vacume operated.
ill check for points in that location, but the car is so dead that the air locks wont even work...it sat for a while...also for some reason i cant turn the key in the trunk lid....dont know if its froze or what..
they look like metal pegs. when u do find them a jump may not do it.
check manual for using a battery charger. i think you need to set it on 6v not 12v
too much juice could fry the computer.
try using some wd 40 or graphite in the lock cylender. may be rusted from sitting.
