New and have questions
Old Feb 23, 2009 | 03:55 PM
jtie's Avatar
Default New and have questions
Hello, i just bought an A4 turbo 1.8 automatic 2004. well question is i dont feel the turbo kicking and should i feel it or is it really to small to feel much. Also i am looking for replacement buttons for the interior cause there alittle worn down but cant seem to find a good site , if someone can help me out or link a good site please.
I was planning on getting a new chip and also a blow out valve but still unsure, has any1 bought a blow out valve for the same car and if so do u like the outcome. last but not least i have filled the wind shield fluid resivor full and nothing is coming out when im trying to wash the windshield, so the only thing is its either clogged or well dont know what else it could be , mabe the motor right?
Old Feb 23, 2009 | 04:35 PM
zippy_gg's Avatar
Do you hear a noise when you actuate the washer lever (indicating the motor is getting energized) ?
If no noise, have you checked the fuse?
Old Feb 23, 2009 | 05:29 PM
jtie's Avatar
Thank you Zippy yes it was fuse now the wipers work but i just ran into another problem,
Some times when i put it in gear instead of just the D lighting up they all actually light up and blink
Old Feb 24, 2009 | 09:05 AM
zippy_gg's Avatar
Did your car happen to get really wet on the inside, on the front passenger side? Check the carpet under that seat...
If wet then your transmission control module (TMC) got wet. Take it out and blow dry it, then re-install and test drive the car.
Old Feb 26, 2009 | 08:56 PM
stasisaudi's Avatar
Default test pipe
hey guys i need some advice. I have a 2006 audi a4 b7 and i want to replace my cat with a test pipe but i dont want the o2 sensors to set off my check engine light and advice on a test pipe that doesnt do that?
Old Feb 27, 2009 | 05:54 PM
zippy_gg's Avatar
What you are doing is called thread hijacking, a frowned upon practice!!!
Please start your own thread and you will be more likely to get replies.
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
