Not Spooling?
Old Dec 5, 2006 | 03:34 AM
Altt180's Avatar
Default Not Spooling?
i have a 2k TT Quat 180hp, normally the turbo with spool up around 3k-ish. recently that hasnt been the case, im getting no odd noises so i doubt it is the turbo itself, and no vacuum leaks, but sometimes the car will boost intermittantly and also at much higher rpms. can this be a N75? or is it something else. if anyone might know help would be appreciated. thanks
Old Dec 5, 2006 | 06:44 AM
Flip's Avatar
Default RE: Not Spooling?
It could be your N75 valve.
Old Dec 5, 2006 | 11:22 AM
Altt180's Avatar
is this a common fix for boost discrepancies? and where can i find one? a stock one that is. oh and how much $?
Old Dec 5, 2006 | 01:31 PM
rayveedub's Avatar
more than likely its the n75 valve, but doulble check all boost plumbing and the dv.
Old Dec 5, 2006 | 01:33 PM
Altt180's Avatar
its a new dv, and i havent found any vacuum leaks so that leads me to the n75 i guess, anyone have a price or a place i can buy a stock one?
Old Dec 5, 2006 | 01:49 PM
rayveedub's Avatar
just go to the stealership there 76 bucks ecs has a upgrade for 90. Just curious, have you ran the computer codes?
Old Dec 5, 2006 | 02:17 PM
2k S4's Avatar
The N75 will throw a CEL, or at least store a code.
VAG the car & see if there are any codes.
Could be...
Bad DV, boost leak, faulty sensor, or N75
Old Dec 6, 2006 | 02:42 AM
Altt180's Avatar
i havent ran a VAG cause its not throwing me a light. i think ill grab me a new n75 and start from there, just reading through similar problems on a search alot of fingers point to n75.
Old Dec 6, 2006 | 02:14 PM
2k S4's Avatar
ORIGINAL: Altt180
Oh, your going the "just throwing parts at it" route.
Even if the CEL isn't on, there can be stored codes. It can be something as simple as a pinched line on the N75, or a faulty connection.
Old Dec 6, 2006 | 02:21 PM
Altt180's Avatar
like i said theres no pinched lines or leaks, ive searched through the compartment and found nothing, if i could get my hands on a VAG then i would run it.
