o2 sensor needs replacing? P1103 (VAG 17511)
Old Aug 8, 2009 | 01:48 PM
asutherland's Avatar
Member
Default o2 sensor needs replacing? P1103 (VAG 17511)
hey guys/gals
Recent VAG COM of my car revealed a problem with the o2 sensor. Which was exactly what I was thinking it was! Bad fuel consumption, lack of power... etc.
HOWEVER - I'm not sure if the o2 sensor needs replacing, or if there's something else funky going on with it. The o2 sensor heater - that's PART of the o2 sensor, correct?
The particular code I'm throwing in VAG is
17511/P1103/004355 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
Possible Solutions
Check Oxygen Sensor Heating for Oxygen Sensor before Catalytic Converter
http://wiki.ross-tech.com/index.php/...ible_Solutions
If I replace my o2 sensor, the one closest to the engine (the easy one to get to? ) will this fix my problem? I have a 2002 A4. (B6)
thanks for any help,
Andrew
Old Aug 8, 2009 | 10:20 PM
Member
If I replace the pre-cat o2 sensor in my 2002 A4 (b6) would it be the following part?
Bosch 17090 OE Type fitment before cat
This would be a wideband sensor, correct?
thanks
Old Sep 20, 2009 | 01:29 AM
Member
Wow, no answers. Oh well... I will post MY resolution, to help with anyone else out there who may come across this problem.
It was indeed the O2 sensor. Replaced with a nice new Bosch, code went away and hasnt come back, and the car has a noticible amount of power back. It also isn't shaky anymore on accel. Yay!
Old Aug 23, 2014 | 05:14 PM
DelgadoAarron's Avatar
Default thanks for answering your own question.
I recently too got that same code 17511 - Oxygen (lambda) sensor heating; B1 S1 p1103 -008 - performance too low.. along with 16523 - oxygen (lambda) sensor B1 S2 p0139 - 004 responce too slow- intermitent. Replaced the first 02 sensor and one went away. Now to replace second one in rear. Sorry no one responded to you. Glad you did and found the solution. Thanx.
Old Dec 22, 2015 | 08:14 AM
S3Pro's Avatar
hey guys/gals
Recent VAG COM of my car revealed a problem with the o2 sensor. Plus you can learn more here about the Venus Factor if it's something that interests you. Which was exactly what I was thinking it was! Bad fuel consumption, lack of power... etc.
The particular code I'm throwing in VAG is.
Andrew
How much did it cost to replace the O2 sensor?
Old Dec 22, 2015 | 08:24 AM
dave944's Avatar
DIY for about $100. Twice that if you can't.
Vannylasky
Jan 29, 2013 05:11 PM
kaden420
Nov 23, 2010 04:45 PM
TommyGunns
Oct 9, 2008 12:20 PM
audi_a4_2003
Jan 1, 2008 03:14 PM
jj2345
Aug 23, 2007 06:44 PM
