oil consumption
any ideas on how much oil our car should be using its a 2001 a4 1.8turbo im thinking possible seals gone in turbo as both tailpipes are wet
many thanks |
RE: oil consumption
I think it depends on where you live as the terrain effects the oil consumption.
I also have a '01 1.8T and I had to fill up it once before it hits the regular 3,000 oil change. There is also a warning that tells you when your oil is low (I wouldn't relly on this as I don't 100% trust computers). |
RE: oil consumption
depends on where you live in the world and how you drive it ( heat burns oil ) no blue smoke from the exhaust is a good sign it in good condition
RE: oil consumption
i hope your using synthetic oil, while any older engine will burn oil its shouldnt be a lot. my 12v has about 150k on it and dosent seem to burning any.
RE: oil consumption
Should not be more that 300ml per 3000Miles.
To see the turbo seals, just take off the exit pipe off the turbo. and check if its wet. If not wet, then ether valve seals, or rings. take off spark plugs, and check the treat, if wet then its the valve seals. if not, then do a compresion test, but most likly its the rings then. other thing is the breather pipes, but they should not be any clogth in them. Wet tail pipe is on the outside, not the inside of the tail pipe. about 5mm on the tip. Wet=oil dry black=rich if wet inside, thats just condinsetion. |
