oil consumption
Old Dec 16, 2006 | 06:08 PM
ou51's Avatar
Default oil consumption
any ideas on how much oil our car should be using its a 2001 a4 1.8turbo im thinking possible seals gone in turbo as both tailpipes are wet
many thanks
Old Dec 17, 2006 | 03:43 PM
kriptonik's Avatar
Default RE: oil consumption
I think it depends on where you live as the terrain effects the oil consumption.
I also have a '01 1.8T and I had to fill up it once before it hits the regular 3,000 oil change.
There is also a warning that tells you when your oil is low (I wouldn't relly on this as I don't 100% trust computers).
Old Dec 17, 2006 | 03:51 PM
techbod's Avatar
depends on where you live in the world and how you drive it ( heat burns oil ) no blue smoke from the exhaust is a good sign it in good condition
Old Dec 24, 2006 | 03:00 AM
SAudi's Avatar
i hope your using synthetic oil, while any older engine will burn oil its shouldnt be a lot. my 12v has about 150k on it and dosent seem to burning any.
Old Dec 24, 2006 | 12:33 PM
kakarot's Avatar
Should not be more that 300ml per 3000Miles.
To see the turbo seals, just take off the exit pipe off the turbo. and check if its wet.
If not wet, then ether valve seals, or rings.
take off spark plugs, and check the treat, if wet then its the valve seals.
if not, then do a compresion test, but most likly its the rings then.
other thing is the breather pipes, but they should not be any clogth in them.
Wet tail pipe is on the outside, not the inside of the tail pipe. about 5mm on the tip.
Wet=oil
dry black=rich
if wet inside, thats just condinsetion.
Juddsmith
Sep 24, 2014 11:05 AM
whoisthis
B7 Models
32
Nov 16, 2010 04:43 PM
wallj
Feb 7, 2010 06:50 PM
ace2525
Aug 26, 2007 09:43 PM
vjreddy
Jul 25, 2007 04:15 PM
