Please Read before posting
Old Apr 14, 2008 | 07:49 PM
ragtoplover's Avatar
Default Navi
Have an 2006A4 Cabrio with Navi, would like to get to antennae jack to install an FM direct adapter, what is the easiest way to get to the jack?
Old Apr 14, 2008 | 07:52 PM
Default RE: Navi
Have 06 A4 Cabrio with Navi, previous owner removed part of theanti-glare coating on the screen, how do I do I fix this?
Old Apr 18, 2008 | 12:49 PM
edelweiss's Avatar
Default RE: speaker cover passenger side
How does one remove and replace the passenger side speaker cover on the door panel? I have a 1999 A6 Quattro wagon. Thanks
Old Oct 26, 2008 | 03:13 PM
Mary's Avatar
Hi,
I have an A3/2006/48,000 and my malfunction indicator lamp just came on, regular service/new battery any idea's
Old Jun 9, 2009 | 07:30 PM
Brian P's Avatar
Default Need Help With Turn Signals
I have my first 2002 A4 Quattro 3.0V6 Auto Tip, the car is very cool! it has 92K miles. the problem is the the driver side turn signals don't work, the flashers work on both sides and the turn signal works fine on the right side.
I'm trying to deside if it is the flasher relay, or the turn signal switch on the column. I disconected the Hasard Flasher above the radio, but with that off the turnsignals on the right side still work. Is there another Relay that I don't know about?
Old Nov 23, 2009 | 12:09 PM
infurce09's Avatar
Banned
Default Please Read before posting
The posting of commercial advertisements is not permitted in this or ANY forum.
If you post advertising of this nature your post will be removed & your account canceled .
Old Jan 14, 2010 | 01:38 AM
Gordon Freeman Jr's Avatar
This thread just goes to prove that our world is filled with idiots who don't or cannot read.
Old Jul 1, 2010 | 07:37 AM
  #18
mkhussey94's Avatar
Look at other sections at evom and dont be afraid to ask people on there are nice as long you aren't stupid .
Old Jan 3, 2011 | 05:13 PM
  #19
denbis's Avatar
Newbie here. MN 2001 S8 w/128k miles. No codes. Heater/AC problem. Summer time on AC hot/warm air comes out of center vents. Several competent (?) indies could not figure anything out. Dealer man finally advised in Dec. flap motor defective after my insisting 3 times to check everything. Replaced @ dealer. Now auto setting will not come off 2 bars fan speed unless forced in manual mode. Defroster vents insist on mostly blowing COLD air. Dealer scratches head. Suggests it might be the heat regulating valve, but not sure. Quote of $2500 to replace with no guarantee to fix problem. Car only worth $10k. Part only @ dealer $1500 and $1000 wholesale. Any ideas? I have a used regulating valve now but unsure if this is the answer? HELP!
Old Jan 13, 2011 | 12:16 PM
  #20
bringamac92's Avatar
