Please Read before posting
Old Mar 21, 2017 | 08:46 PM
  #31
Giovanni 2's Avatar
I have a s4 2.7t 2000 and Iam swapping everything to a4 avant 2.4 2000 as the s4 is accident and want to know which rear subframe will fit on a4 cos the s4 want fit its different thanks
Old Apr 18, 2017 | 05:12 PM
  #32
Wifes Audi's Avatar
Default ESP light does not turn off
Hello, I am new to the forum and new to these cars (Wife loves it!). The car specs are as follows. 2008 A4 2.0T S-Series - 102000 mi. I have an ESP "Car with squiggly lines" light stuck on that will not go off when pushing in the ESP button/switch? The ABS seems to be kicking in during slow sharp turns while breaking such as pulling into a parking spot or driveway "really slow speeds" This breaking action along with the light being on leads me to believe something is going on with the ABS system. Any thoughts/solutions/questions? Breaks work fine under all other regular driving conditions. No codes showing up!
Old Nov 10, 2017 | 11:49 PM
  #33
warren90anthony's Avatar
Air filter disconnect few times over the following weeks. I could not detect ANY leaks - I removed the thermostat and took the car for a test run with the same result. I changed the temperature sending unit - same result.
Appreciate any advice.
Old Jul 20, 2020 | 01:37 PM
  #34
KateCallMe's Avatar
I can show myself for free)) but only on this site👅💦💦👇👇👇 https://datingukrwomen.com/katecall
Old Jul 20, 2020 | 01:38 PM
  #35
KateCallMe's Avatar
Default Love me
Old Oct 11, 2021 | 09:04 AM
  #36
dulichvamuasam's Avatar
Hello everyone, I'm new member this forum. Hope everone helf me.
Old Mar 22, 2022 | 02:25 PM
  #37
chucky35uk's Avatar
Default Audi a1 sline idle way too high.
Hi.
I have an Audi A1 s line. 2018. 18000 miles.
I’ve only had it since Dec 1st 22.
The problem is the idle speed is way too high in my opinion. It’s sitting at 1400 rpm. This is cold start and when fully heated up.
It’s rigidly on 1400….no wavering and not fluctuating at all. Which makes me feel it’s not a vaccum leak. I have connected my obd11 pro and run a full diagnostic….but it’s coming up with no faults at all. Is it possible the iac valve has failed?
any idea folks? 🤷🏻‍♂️
Old Feb 19, 2024 | 11:47 PM
  #38
davideidson's Avatar
yep that is the rule. thanks for reminding
MarcelloM
Sep 2, 2008 06:49 AM
AhDee_tt
Jul 4, 2008 03:32 PM
2twins.7
May 26, 2008 12:40 AM
onepoint8tee
Sep 25, 2006 10:09 PM
trailboss
Jul 1, 2006 05:17 AM
