possible purchase, baby due in Aug, need help
Posted in New member area, but moved here
06 Audi A3 2.0T - 117,000miles Guy is asking $6,450 and trying to figure out if it's a decent buy with the current issues it has or if I should get him down on price. Any help is appreciated, with a baby on the way I need something that won't break the bank in getting it on the road and repairs. Thanks in advance! ...tags expire sometime in 2015, so needs to be reinspected here in Delaware, and the check engine light is on, throwing these codes: Address 01: Engine Labels: 06F-907-115-AXX.lbl Control Module Part Number: 8P0 907 115 B HW: 8P0 907 115 B Component and/or Version: 2.0l R4/4V TFSI 0080 Software Coding: 0103010A1C070160 Work Shop Code: WSC 07322 444 84037 VCID: 31691406A8F976962BD-8064 9 Faults Found: 008577 - Performance Malfunction in Cooling System P2181 - 008 - - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 0 Fault Frequency: 21 Reset counter: 255 Mileage: 166588 km Time Indication: 0 Date: 2013.05.30 Time: 06:01:51 Freeze Frame: RPM: 2415 /min Load: 32.9 % Speed: 96.0 km/h Temperature: 75.0°C Temperature: 24.0°C Absolute Pres.: 1010.0 mbar Voltage: 14.351 V 001287 - Idle Control System RPM P0507 - 001 - Higher than Expected. - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 0 Fault Frequency: 54 Reset counter: 255 Mileage: 179249 km Time Indication: 0 Date: 2014.01.15 Time: 11:11:05 Freeze Frame: RPM: 1026 /min Load: 14.5 % Speed: 0.0 km/h Temperature: 71.0°C Temperature: 22.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.224 V 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 008 - - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 0 Fault Frequency: 15 Reset counter: 255 Mileage: 179820 km Time Indication: 0 Date: 2014.01.20 Time: 12:00:28 Freeze Frame: RPM: 876 /min Load: 25.9 % Speed: 0.0 km/h Temperature: 10.0°C Temperature: 5.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.478 V 000769 - Cylinder 1 P0301 - 008 - Misfire Detected - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 0 Fault Frequency: 15 Reset counter: 255 Mileage: 179820 km Time Indication: 0 Date: 2014.01.20 Time: 12:00:51 Freeze Frame: RPM: 917 /min Load: 26.7 % Speed: 0.0 km/h Temperature: 16.0°C Temperature: 5.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.605 V 000771 - Cylinder 3 P0303 - 008 - Misfire Detected - Intermittent - MIL ON Freeze Frame: Fault Status: 10101000 Fault Priority: 0 Fault Frequency: 11 Reset counter: 255 Mileage: 179820 km Time Indication: 0 Date: 2014.01.20 Time: 12:00:51 Freeze Frame: RPM: 917 /min Load: 26.7 % Speed: 0.0 km/h Temperature: 16.0°C Temperature: 5.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.605 V 000772 - Cylinder 4 P0304 - 008 - Misfire Detected - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 0 Fault Frequency: 15 Reset counter: 255 Mileage: 179820 km Time Indication: 0 Date: 2014.01.20 Time: 12:00:51 Freeze Frame: RPM: 917 /min Load: 26.7 % Speed: 0.0 km/h Temperature: 16.0°C Temperature: 5.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.605 V 000770 - Cylinder 2 P0302 - 008 - Misfire Detected - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 12 Reset counter: 255 Mileage: 179820 km Time Indication: 0 Date: 2014.01.20 Time: 12:00:51 Freeze Frame: RPM: 917 /min Load: 26.7 % Speed: 0.0 km/h Temperature: 16.0°C Temperature: 5.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.605 V 004506 - Fuel Pressure Sensor (G247) P119A - 001 - Malfunction - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 180262 km Time Indication: 0 Date: 2014.01.23 Time: 14:53:17 Freeze Frame: RPM: 869 /min Load: 14.5 % Speed: 0.0 km/h Temperature: 62.0°C Temperature: 3.0°C Absolute Pres.: 1010.0 mbar Voltage: 14.478 V 001089 - EVAP Emission Control Sys P0441 - 001 - Incorrect Flow - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 181004 km Time Indication: 0 Date: 2014.01.28 Time: 12:01:08 Freeze Frame: RPM: 859 /min Load: 15.3 % Speed: 0.0 km/h Temperature: 72.0°C Temperature: 7.0°C Absolute Pres.: 1020.0 mbar Voltage: 14.478 V 008825 - Leak in Air Intake system P2279 - 002 - |
