possible purchase, baby due in Aug, need help
Posted in New member area, but moved here
06 Audi A3 2.0T - 117,000miles
Guy is asking $6,450 and trying to figure out if it's a decent buy with the current issues it has or if I should get him down on price. Any help is appreciated, with a baby on the way I need something that won't break the bank in getting it on the road and repairs. Thanks in advance!
...tags expire sometime in 2015, so needs to be reinspected here in Delaware, and the check engine light is on, throwing these codes:
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8P0 907 115 B HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0080
Software Coding: 0103010A1C070160
Work Shop Code: WSC 07322 444 84037
VCID: 31691406A8F976962BD-8064
9 Faults Found:
008577 - Performance Malfunction in Cooling System
P2181 - 008 - - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 21
Reset counter: 255
Mileage: 166588 km
Time Indication: 0
Date: 2013.05.30
Time: 06:01:51
Freeze Frame:
RPM: 2415 /min
Load: 32.9 %
Speed: 96.0 km/h
Temperature: 75.0°C
Temperature: 24.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 54
Reset counter: 255
Mileage: 179249 km
Time Indication: 0
Date: 2014.01.15
Time: 11:11:05
Freeze Frame:
RPM: 1026 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 22.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:28
Freeze Frame:
RPM: 876 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 10.0°C
Temperature: 5.0°C
Voltage: 14.478 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:51
Freeze Frame:
RPM: 917 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 5.0°C
Voltage: 14.605 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:51
Freeze Frame:
RPM: 917 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 5.0°C
Voltage: 14.605 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:51
Freeze Frame:
RPM: 917 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 5.0°C
Voltage: 14.605 V
000770 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:51
Freeze Frame:
RPM: 917 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 5.0°C
Voltage: 14.605 V
004506 - Fuel Pressure Sensor (G247)
P119A - 001 - Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 180262 km
Time Indication: 0
Date: 2014.01.23
Time: 14:53:17
Freeze Frame:
RPM: 869 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 62.0°C
Temperature: 3.0°C
Voltage: 14.478 V
001089 - EVAP Emission Control Sys
P0441 - 001 - Incorrect Flow - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181004 km
Time Indication: 0
Date: 2014.01.28
Time: 12:01:08
Freeze Frame:
RPM: 859 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 7.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.478 V
008825 - Leak in Air Intake system
P2279 - 002 -
9 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 21
Reset counter: 255
Mileage: 166588 km
Time Indication: 0
Date: 2013.05.30
Time: 06:01:51
Freeze Frame:
RPM: 2415 /min
Load: 32.9 %
Speed: 96.0 km/h
Temperature: 75.0°C
Temperature: 24.0°C
Voltage: 14.351 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 54
Reset counter: 255
Mileage: 179249 km
Time Indication: 0
Date: 2014.01.15
Time: 11:11:05
Freeze Frame:
RPM: 1026 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 71.0°C
Temperature: 22.0°C
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:28
Freeze Frame:
RPM: 876 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 10.0°C
Temperature: 5.0°C
Voltage: 14.478 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:51
Freeze Frame:
RPM: 917 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 5.0°C
Voltage: 14.605 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:51
Freeze Frame:
RPM: 917 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 5.0°C
Voltage: 14.605 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:51
Freeze Frame:
RPM: 917 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 5.0°C
Voltage: 14.605 V
000770 - Cylinder 2
Freeze Frame:
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 179820 km
Time Indication: 0
Date: 2014.01.20
Time: 12:00:51
Freeze Frame:
RPM: 917 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 5.0°C
Voltage: 14.605 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 180262 km
Time Indication: 0
Date: 2014.01.23
Time: 14:53:17
Freeze Frame:
RPM: 869 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 62.0°C
Temperature: 3.0°C
Voltage: 14.478 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 181004 km
Time Indication: 0
Date: 2014.01.28
Time: 12:01:08
Freeze Frame:
RPM: 859 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 7.0°C
Voltage: 14.478 V
P2279 - 002 -
jaystay42
Apr 14, 2015 09:03 PM
